Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (1 invisible), 156 guests, and 2 robots.
Topics128,290
Posts1,058,562
Members48,492
#1479832 12/20/2022 7:19 PM
Hi all, I plan on installing three point retractable seatbelts in my ‘53 5 window with original bench seat and cab mounted fuel tank. I have been researching seat belts. I am looking at going with either Juliano’s or Seat Belts Plus. Does anyone have advice about these belts before I place an order, which brand I should go with, preferably based upon experience. Also, the Seat Belts Plus have two options, one option features a large retractor with a longer oval shaped mounting tab on the end of the lap belt (similar to the Juliano’s belts), the other option must be a “smaller” retractor that has a small mounting tab on the end of the lap belt. Any insight about those options would be appreciated. Thank you.
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
AD Addict & Tinkerer
Here is how I installed 3 point belts from “Seat Belts Plus” in my ‘52 5 window. Read the entire thread, as there is allot of info from different bolters that installed belts.
[LINK]
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for the reply. I have read that post, and will read it again as well as study the pics. However, I was looking for recommendations and opinions about the two brands, not necessarily how to mount them. I ended up ordering from Seat Belts Plus, and I am currently in the process of mounting them.
Post pictures of your progress and finished product.
1950 Chevrolet 3100 (Ol' Roy)
Here are a few pics.
For the retractor I made a bracket that ties into the seat bulkhead, the adjustable seat mount studs, and through the floor. There is a bracket under the floor that welds to the cab mount bracket.
For the shoulder mount I plug welded a couple plates with a welded nut behind the door/window frame, a typical technique. I machined a bushing to allow it to pivot accordingly.
For the latch mechanism and lap belts, I made a couple brackets that go through the floor with a couple accompanying plates under the floor. Most of my floor is 16g metal that bends up at 90 degrees and marries the seat bulkhead, so it is plenty strong.
I have a seat belt kit from Seat Belts Plus that I need to install. Interesting ideas on the lower mounts. I used the plate from their installation kit on the shoulder mounts. Have a little more room than you did, because my truck is a 3 window cab. Thanks for posting the photos.
Nice installation, and thanks for the follow-up!
Phil
Project Journals
Here are a few more photos that might be helpful. I folded over the metal edges on the openings in the seat frame cutouts.
What's the story on the treefrog green engine?
It matches the rest of the tree frog green!
Moderated by  ndkid275, Phak1
