0 members (),
47
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Hello, Does anyone know if there is a double pulley available for a 1955 235 engine? I am working on installing power steering. I have seen some aftermarket pulleys available but not sure if I have to replace the whole damper plate like the ones from damper dudes, or can use one of the pulleys from a place like cpp. Perhaps someone knows if there were other 235 engines that used a double pulley but would still fit the 55 engine? Thanks in advance, Judson | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Use a double sheave damper for a 250 six. It requires a little machining of the snout to make the grooves line up with the water pump and generator/alternator pulleys (shorten the snout 1/4" and move the seal surface OD back the same distance). any machinist worthy of the name can do the modification in a few minutes. www.ebay.com/itm/185626953914?Jerry
| | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Ok. Thanks for that lead Jerry. Judson | | |
