7 members (3B, Bill Hanlon, TooMany2count, Otto Skorzeny, Peggy M, GDW, 1 invisible), 114 guests, and 2 robots.
Topics128,139
Posts1,056,460
Members48,441
#1481381 01/01/2023 8:29 PM
I’ve been chasing a terribly poor idle and focusing on my Zenith 10920 carb to be the cause. Now I just completely rebuilt the carb again with a new kit from carbking. This time I bought the 2 Zenith check valve removal and installation tools so I could replace them as well. With the carb completely disassembled including the checks and ball, I soaked the works in a gallon carb cleaner for 3 days before rinsing, running a thin wire through every passage then thoroughly blowing out everything with compressed air. Then I soaked again for 24 hours and repeated. This carb is now cleaner than a new baby bottle with new parts installed with the proper tools.
Meanwhile each time I’ve cleaned the carb I fall back 2 steps or more.
I think I’ve been chasing a red herring. I’ve gone from a terrible idle to nothing. Don’t want to run at all. It tries to start but sounds like what you might expect if the spark plug wires were out of order (they are not!)
Now to the point, with distributor cap off I can rotate the rotor a few degrees CW by hand and feel spring tension. When I let go it moves back CCW to a stop. However I can then turn it slightly more CCW and it stops there. With a slight turn back CW to the initial stop it will stay there but I can hear a click when moving it there.
Is there a bonafide expert reading this who can tell me this is abnormal, or can someone do me the immense favor of removing you distributor cap to check and see if it does this same thing?
Many thanks to all who may help me!!
Mike Barnes
1950 GMC 1-ton pickup
B Online: Content
Originally Posted by buoymaker
Unfortunately I don't have a parts diagram of a 228 distributor for show-n-tell.
Buoymaker: Picture is from '53 GMC Master Parts Book. Same distributor parts from '39 thru '53.
O Online: Content
Verify your condenser is working. If you have a spare, even a used one, put it on and see if there is any change at all. Don't assume that because a part is brand new that it can't be the source of a problem.
What sort of spark are you getting? Is the center dizzy wire from the coil making a good spark? Plugs sparking?
Check the primary wire to the dizzy. I had a frayed one on another car and appeared fine. When I started poking around the wire broke off of the ring terminal at the points.
1950 Chevrolet 3100 (Ol' Roy)
Change the condenser.
Thanks for the advice. I’ll double check distributor is fully seated, install my new Jon G condenser, and follow up.
Mike Barnes
SUCCESS!!!! New Jon G condenser and clean rebuilt carb did the trick. Runs and idles beautifully now!
Mike Barnes
"I love it when a plan comes together!"
Thanks Jerry, we are lucky to have you!
Mike Barnes
O Online: Content
Excellent.
AD Addict & Tinkerer
Great news! Thanks for the follow-up!
Phil
Project Journals
Stovebolt Gallery Forum
