8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H), 60 guests, and 0 robots.
Topics128,119
Posts1,056,311
Members48,439
#1481046 12/30/2022 7:00 PM
46 1/2 ton. Just knocked these parts out of the transmission end of my torque tube. Not what I expected or have seen. The Oakie bushings I have seen are 1 piece. Is this an earlier design? I’m 95% sure I have them oriented correctly trans to rear. right to left would be trans to rear. Not sure if the left (rear) section is facing the right way. I knocked it apart myself and the pieces flew. I believe the copper shim was in there as well. Was expecting 1 piece not 3. Appreciate any help. Happy New Year.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Those are the original bushings and seal that the factory installed. The oakie bushing is and aftermarket replacement of the two bushing factory setup with a combination assembly.
Is it made in Muskogee?
1950 Chevrolet 3100 (Ol' Roy)
Curmudgeon
Curmudgeon
Unlike the song, they came from National Machine Works in Oklahoma City.
Here is a little (actually a lot) of information about the Okie Bushing.. (Thank You, Jim Carter)
It is (was ?) indeed originally made in Oklahoma.
Most likely they are made elsewhere now?
buoymaker beat me to it - thanks
Until I saw the picture, I assumed it had an oakum seal and hence the nickname.
Thanks all.
Curmudgeon
Curmudgeon
"The Oakie bushings I have seen are 1 piece. Is this an earlier design?"
Original is two bushings and one seal. Original bushings held in place by a dowel.
"I’m 95% sure I have them oriented correctly trans to rear. right to left would be trans to rear."
See attached picture
"I believe the copper shim was in there as well."
The copper is part of a bushing.
Does ANYBODY have the okie bushing puller that I could borrow,rent or buy ? They are next to impossible to get from the online parts outlets and have been on back order FO months
Thanks Wes
[email protected]
I will see if I can find mine.
Chevs of the 40s rents/sell one.. However, this is a confusing listing/offer.
I think we should clear up the name of the tool. I believe Chevs of the 40s called it an Oakie Bushing Puller. It is really an original front bushing puller that is used before an Oakie bushing is installed.
1951 1 Ton Completed
