1 members (‘37ChevyPU),
86
Mod | | | Forums66 Topics128,211 Posts1,057,476 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have just posted pictures of my freshly powdercoated frame for my Detroit Diesel 4-53T project truck.
Click the link below and go to the last 5 pictures in the Diesel folder.
Grigg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Very nice Grigg....I have been thinking of a diesel swap also.
I'm sticking with a '54-'55 1st....maybe a 3100 panel with a 5 cylinder Mercedes turbo diesel/auto....or a 3800 pickup or dually....or an other BIGBOLT with a Cummins 5.9/NV4500...NV5600 would really be special!... hey, dreaming don't cost nothing....
Since I've sold my '04 F**d Ranger and drive an '85 MB 190d as a daily driver I am more convinced diesel is the way to go...34 mpg with 173k on the clock.
How come GM does not put a diesel in one of the small pickups ?....I no at least 4 guys that would buy one....
Anyway...keep up the good work...Jim 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Boy that frame looks good Grigg, not at all like mine! Rick In Va | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Hey Grigg, How expensive is it to have a frame powdercoated? Did you sandblast everything before sending it out or did the powder coat guys do it for you? Are there any "down sides" to powder coating? Thanks! Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Hi Mike, My frame with a loose cross member, 4 running board brackets, trailer hitch, and 12 other small pieces cost me 350 to have sand blasted and 689 to have powder coated, and 160 for gas to drag the truck and trailer around for a week.
I had the sand blasting done before I took it to powder coating, he can't blast anything that big at the powder coating place, but can do smaller stuff. The day it was done being blasted I took it straight to the powder coater and it was done the very next day. So, 2 days total, and it is very important to have it done ASAP after blasting so stuff won't rust.
The down sides to powder coating are that it can't be "touched up" like paint, you would have to use paint if you had a scratch. The other downside, I think, is that you can't use any filler under it to smooth stuff up, the 400 degrees would just pop it off. So what you see sandblasted is what you get powder coated. Powder coating tends to smooth things out a bit more than paint though, so it was fine for my frame. On the up side, it is very tough. The trailer hitch I had blasted had been powder coated previously, the blaster said it was the hardest part of the job to blast it. I also found that powder coating is only slightly more expensive than a really good PPG primer that was my second choice, and that was with me spraying it. If you were going to prime and color coat powder coating may even be cheaper than paint.
I think that for a frame powder coating is the way to go. Although if you were making an all out show vehicle paint would be better because of the filler and touch up issues.
Hope this helps, Grigg | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Nice way to start ie. with a clean frame. It looks great! | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | lookin' good, engine looks nice also, I like the color.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Grigg, Thanks for the info! Mike B  | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Looks great Grigg! It is going to be the neatest truck!!!
Jim
Good luck with your project!
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | More power to you. You are a man after my own heart. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks guys, With luck, by next weekend I will have my freshly painted axles installed as well as my engine and transmission. Grigg | | |
