| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | So getting ready to replace my water pump, should you use sealant between block and gasket? 216 motor. Thanks
1953 with a 216
| | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | I use Permatex Super 300. It's a black brush-on liquid that was originally made for use around aviation gasoline. It's a much better sealant than the light brown 3-H Permatex liquid. Lots of listings on Ebay. Jerry
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Ditto what Jerry said. I used Permatex Super-300 NO Leaks!
1950 Chevy 3100
