0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#148032 08/24/2006 11:51 PM
Can someone send me a pic of how the mirror is mounted either on the door or otherwise for a 41 to 47EC cab? No matter how tight I make mine it blows back to the window when I drive it. I think the mount I have is not the same as the original. I would greatly appreciate any help with this.
Matt
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
#148033 08/26/2006 12:03 AM
I've looked at my COE versions, and it appears to be the tightness of the bolt running thru as a pin (if that is factory). Essentially it tightens it up against the door portion of the hinge. They don't move, but then again, there looks to be a significant amount of surface rust on em helping out. How fast you going in that thing anyway? smile
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#148034 08/26/2006 8:30 AM
I did a little better look at all three. One of them has what looks like aftermarket (but old) braces that run from near the outer edge of the mirror bracket back and bolt to the door. Another has a hole that is drilled and tapped in the door hinge bracket with a "set" bolt in it. That would be the best way to do it. Hope this helps.
1947 Chevy COE
#148035 08/27/2006 4:53 PM
I'm only going 40 or so. She don't set any land speed records. I have a part that hooks to the hinge pin on the door. Then there are other pieces that don't seem to belong. Either way there is nothing that secures it tightly. If someone had a big bolt 41 to 46 cab mirror pic they can email to me so I know if I even have the right parts. The mirror is hooked to a piece that looks to need two bolt to mount onto something other that what it is hooked to. There seems to be another piece floating in the breeze that does nothing but scratch the hinge.
There are 2 holes in the hinge frame but nothing I have hooked to the mirror will fit the holes.
Matt
#148036 09/07/2006 6:56 AM
Here are pictures of two big trucks, both 46. The top one may be like yours in that there are two holes in the bracket which here are used with set screws. This is probably the way to go for you. The lower one is also factory looking but using no set screws. It is also very tight. Are you sure you have plenty of threads on your "pin bolts"? maybe your nut is tight before they close up on the door portion of the hinge..
If you tighten them up good with plenty of thread they should not move. Hope this helps.
http://www.redemerconcepts.com/truck/mirrorbrackets.jpg
1947 Chevy COE
#148037 09/07/2006 12:49 PM
Huge help....wow thanks....appreciate the pic...now I know what I'm missing....
