4 members (Patina 54, sron48, Otto Skorzeny, FAST55), 114 guests, and 2 robots.
Topics128,034
Posts1,055,440
Members48,422
#1479274 12/16/2022 10:24 PM
Hello i have a GMC 348 engine, can any body tell me what size freeze plug goes in the back of the cylinder head. Thanks .
Howardwade #1479282 12/16/2022 10:48 PM
GMC 348? More likely a 248. I'll measure the plug in the back of my 302 head later tonight and verify that the 228-235-248-256-270-302 GMC heads all use the same plugs. Gotta go now.
Howardwade #1479296 12/16/2022 11:28 PM
Isn't there a GMC V8 (Pontiac) with 348 cubic inches? It's a downsized version of the Pontiac 370, so the same freeze plugs should work that fit the 370 engine.
Howardwade #1479312 12/17/2022 12:55 AM
L6 or V8?
Did they use Chevy "W" engines in G.M.C.?
Howardwade #1479316 12/17/2022 1:07 AM
From Wikipedia:
Pontiac
Prior to developing its own engines, smaller GMC's used the Pontiac V8 engine. They used the Pontiac 287-cubic-inch (4.7 L) engine for 1955 and 316-cubic-inch (5.2 L) engine in 1956, but advertised the engines as the "GMC 288" and "GMC 316". They used Pontiac's 347-cubic-inch (5.7 L) in 1957. For 1958, GMC reduced the bore of Pontiac's 370-cubic-inch (6.1 L) to 3.875 in (98.4 mm), resulting in a displacement of 336-cubic-inch (5.5 L). In Canada. For 1959, as the Pontiac engine's stroke was lengthened to 3.75 in (95.3 mm), a further bore reduction to 3.78 in (96.0 mm) was done to keep the displacement at approx. 336 cubic inches (5.5 L) (336.7).
Yes, I know- - - - -probably a less-than reliable source!
All 1939-1960 GMC six cylinder gas engines from 228 to 503 cubic inches use the same 1 1/4" plug at the rear of the head, GM part number 663032.
Bill Hanlon #1479991 12/22/2022 8:36 AM
Hello yes sorry its a straight six 248. I tried a 11/4 and its to big. Thanks
Howardwade #1480010 12/22/2022 2:13 PM
Don't know what to say. Below is from 1939-53 GMC Master Parts Book. 1955.2-1960 MPB reads the same. I don't have a 1954-1955.1 book, but I doubt GMC would have changed it for a year and then changed it back.
Howardwade #1480019 12/22/2022 3:20 PM
Sorry i got confused with engine numbers, the engine is a 302.
Howardwade #1480041 12/22/2022 5:40 PM
The GMC Master parts books say the 663062 1 1/4" plugs fit the back of the head on 228, 236, 248, 256, 270, 302, 360, 426 and 502 cubic inch six cylinder engines made from 1939 through 1960.
Bill Hanlon #1480153 12/23/2022 6:58 AM
Mmm i tried a 1 1/4 and no way will it fit.
Howardwade #1480163 12/23/2022 1:23 PM
Howardwade,
Can you provide some pictures???
Start with the head, with one that shows the head casting number. Then a pic of the hole and the currently too large 1-1/4" plug in comparison to the hole.
Post what you have and then maybe we can better help out???
Hoping we can help you figures this out! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Howardwade #1480301 12/24/2022 10:09 PM
If the old one rusted out are you sure you got the remnant of the ring out?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Howardwade #1482231 01/07/2023 6:04 PM
Here is pic of the head in question and freeze plug hole
Howardwade #1482243 01/07/2023 7:40 PM
where here?
Howardwade #1482267 01/07/2023 11:00 PM
Howardwade,
Your picture did not show up. headscratch
Take a peek at this linked page of instructions to hopefully help you get a pic or two posted: Picture Posting Guide
If you continue to have trouble, feel free to PM me and we can talk further on trying to solve your picture posting problem. wave
~ Dan
Howardwade #1482944 01/11/2023 7:08 PM
I had to move my 302 head today to get into something stored beneath it, so I thought I'd prove my point that all 1939-1960 GMC straight six engines use the same size (1 1/4") freeze plug on the back of the head. My knowledge was strictly book learning as that is what my GMC parts catalogs say.
To quote Gomer Pyle, "Surprise, Surprise, Surprise!"
Pictures are from GMC casting number shown. The 3983 head was used on all 302 engines, 1952-1962.
Proper plug should be a Dorman 555-022.
Howardwade #1482962 01/11/2023 9:50 PM
Crusing in the Passing Lane
There are 4 heads that fit 302’s, don’t remember the numbers, offhand!
Ed
