3 members (Gdads51, 68ironhead, Peggy M), 94 guests, and 2 robots.
Topics128,118
Posts1,056,302
Members48,439
#1477162 12/01/2022 11:43 PM
Would love to here form anyone that has replaced the front lower section,upper wheel arch and rear lower section. Any tips that may help or any problems you ran into.
Sir Searchalot
Sir Searchalot
Been there done that. Email because this will take some time and many posts.....and more pics.
The sheetmetal is a perfect match for a ‘59-‘66 fleetside bed. You can buy the bedsides new.
Have ordered patch panels for 60 to 66 fleetside. Hope they'll work out.
Any updates on the sheet metal? Quality? Supplier? Fitment?
I’m after some and would like to end up with decent parts.
Sent you a PM. Don't know how much metal you have to replace.
Sir Searchalot
Sir Searchalot
Have you actually repaired the lower sheet metal on a 55.2-59 suburban or panel? If so what did you actually use?
Yes I have. I used a NOS patch panel for a 60-66 Fleetside to repair my 55 Suburban. It wasn’t completely rotted out, but my truck needed several pieces of the patch panel. I can’t speak to the differences between a NOS and a new panel, but mine was a perfect fit.
Here are a few pics of the left side patch panels for the 60 to 66 fleetside. You can see that their not going to be an exact fit. The inner panel is alot different then the original inner panel. I plan on cutting and using the rear patch. Like Napco Man said it going to depend on how much has to be replaced and where. I'm going to have to Fab some of my repair areas. Will post some pics.
That’s a completely different panel than the one I used. Mine was almost the entire side and included the wheel well. Good luck on your project.
Napco Man: I also have a 57 Burb. Used to live in Virginia. Did you find your patch panel from a junkyard? Anthony "Old Tin" Thomas. [Ecclesia]
1949 Panel Truck; rebuilt '57 235; still deciding on tranny, will do disc brake upgrade.
He might thinking of THIS ONE. Key there is almost. Long forward and short to the rear. Wheel wells match outside.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
