7 members (GMCJammer51, Youngin' Tut 59, Tim Canfield, jmoore, 3B, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
Page 2 of 2 1 2
Originally Posted by Truckrolet
Jag talar inte svenska, Just hope none of this is a bad word or something.
You will have to slowly train us all.
Well, you just did wink No worries, all you said was "I don't speak Swedish" so it's all good thumbs_up
1957 Chevrolet 6500/86 Fire Truck
"Ignis"
Sweden
In DITY Gallery
Stovebolt Volunteer Fire Department
I guess that truck of yours is referred to as the Flat Face Cowl 6502 Model. If the windshield was included its called Windshield Cowl. Shipping weight of the 6502 is 4380 lbs. That is just the Chevrolet stuff not including the aftermarket body etc.
Frame: Channel side rails, 7 cross members, Rails 9 1/8 x 3 x 1/4 inches, Section Modulus 9.41. Rear axle 7.20 to 1. Have more info if needed.
Your front fender emblems are on the wrong sides. Picky me.
I just drag the picture into the little box to post pictures, no typing needed.
Any idea what the cab is from? I doubt it was completely made up from scratch. Maybe a Volvo or MAN
1950 Chevrolet 3100 (Ol' Roy)
I understand! Thanks very much for the info! I don't know about the windshield, I haven't seen any other 57 chevys with split windshield though so I assumed it was part of the swedish cab.
Haha, I hadn't even noticed the emblems. Gonna look into that and see if I can put them on correctly. Or maybe just leave it, as a testament to the GM nordic build quality haha.
"Ignis"
Sweden
In DITY Gallery
According to the info from a Swedish forum there should be an identifying builders plaque or something similar somewhere in the cab, but I haven't been able to find it... Maybe it's missing or just well hidden. If I do find it I'll report back!
I did some digging and you may actually be onto something, look at this Volvo L370 fire truck from 1955 and compare the aluminium side trim and door handles to those on my truck:
"Ignis"
Sweden
In DITY Gallery
That's it. It is a Volvo.
The windshield shape and door handles are also identical. Nobody is going to scratch build scalloped door handle pockets like that.
Notice also the door hinges. The two upper hinges visible on the Volvo are in the exact position as those on your truck.
So is this truck a Volvrolet or is it a Chevrolo?
AD Addict & Tinkerer
Gentlemen, now that we have established what this truck is fabricated from, can we get back on subject? Les we forgot, This is the “Engine Shop“.
When I first got my non running truck, I rebuilt the Rochester B carb, then took it apart two more times positive it was a fuel issue. It turned out to be a bad condenser. Once I changed it, it started right up and ran great.
Phil
Project Journals
Stovebolt Gallery Forum
Well, actually... It's probably not a Volvo-mix after all. Got some more info from a Swedish Vintage Truck forum, and according to the info there the chances of the cab being Volvo made is pretty much nonexistent. The similarities between parts is according to their experts more likely to be fire engine specific rather than volvo specific, and the cabs were most likely built by various coach builders around the country after the trucks came here as flat face cowls. Gonna have to see about finding that manufacturers plate...
"Ignis"
Sweden
In DITY Gallery
You're right, pardon the off topic discussion. It's easy to get sidetracked.
Is there any way to test the condition of a condenser or is it simply a matter of "might be bad, switch it out"?
"Ignis"
Sweden
In DITY Gallery
If you installed a new condenser along with points and rotor, I'd just put the original one back on and see what happens.
A 60 year old condenser is better than the Chinese new ones. In the meantime, get one of Jon Goodman's 200,000 hr condensers.
https://www.stovebolt.com/ubbthread...native-condenser-update.html#Post1388813
Have contacted Jon about purchasing one of his condensers thumbs_up
"Ignis"
Sweden
In DITY Gallery
Page 2 of 2 1 2
