4 members (Greg_H, tclederman, Peggy M, Napco Man), 117 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#1478231 12/09/2022 6:24 PM
I was adjusting the valves on my 1954 235 6 cylinder. One of the adjustment screws was seized to the Locking nut so I bought a new one. The new one has a ball bearing on the end of the screw that I can compress. The other 11 do not.
The engine has solid lifters. Could the one that I bought before hydraulic lifters?
Can I use the new one if I adjust the valve so that there is no lash?
Any help would be greatly appreciated.
I have attached a photo of the original one on top with the one that I bought on the bottom
1946 1/2 ton Chevy Pickup
1954 235 cu in
3 speed on the floor
Weird. It’s compress-able?
PM me. Pretty sure I have a few non-compressable ones around.
1951 3100
Insomniac
Insomniac
Where did you buy it from?
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
Chevs of the forties
1954 235 cu in
Gary,
What part number did you order?
Never heard of a compressible adjuster??? headscratch
~ Dan
1951 Chevy 3 window 3100
Authorized Pest
Authorized Pest
I saw they sell Rocker arm stuff on Walmart.com!! smile
~ Peggy M
1949 Chevrolet 3804
Curmudgeon
Curmudgeon
Q-T Valve Screws circa 1953.
Are they as advertised? Are they any good?
If they were, we would have seen/heard more of them.
Insomniac
Insomniac
Maybe that's how Chevs of the Forties justifies charging $15 each for the screws. Unlike the stock screws, they have a ball bearing and spring.
Gord πŸ‡¨πŸ‡¦
Seems like a good idea that ought to quiet them down, but might complicate adjustment a bit.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
I don't know the part number.
I installed it and set it at 006. Really noisy! I tightened it down so there was no Lash. Solid lifters in this engine . Really quiet and runs great.
I'm chasing a noise that I thought was a valve problem. It's not. I think I've got some blow by problems.
1954 235 cu in
An exhaust leak can sound an awful lot like valve noise.
1951 3100
Curmudgeon
Curmudgeon
Those adjusters are spring loaded inside. After ~70 years I would not trust spring tension and their reliability IMHO.
I have no idea if they may cause damage to your pushrods or other drivetrain parts.
If the seller/business lists them as 837385 or reproduction replacement for 837385 then I would ask for a refund.
I agree. That was one of the first things that I checked. The exhaust system is tight all the way from the exhaust ports to the muffler
1954 235 cu in
I would love to hear from anybody that has ever used these. Currently I only have one installed on one valve. I don't know how this would work with a setting of 018. 0.006 seem to work really well.
1954 235 cu in
Curmudgeon
Curmudgeon
Why don't you contact some of the Portland Oregon area classic vehicle clubs. Maybe there would be someone who remembers the factory and can fill you in. Let us know if you find anything. All I could find is this old ad from the 1953 Popular Mechanics.
O Online: Content
The poor man's hydraulic lifters.
1950 Chevrolet 3100 (Ol' Roy)
Chevy L6 stovebolt engines used small extra springs bearing directly on the tappet (called "rev kit") to reduce noise before WW2.
