1 members (sron48), 104 guests, and 2 robots.
Topics128,154
Posts1,056,856
Members48,456
#1478114 12/08/2022 8:16 PM
I need about 3 of them, for 235, did a search here first. So far none of the truck parts places have them.
Crusing in the Passing Lane
Wrecking yard!
Ed
O Online: Content
Someone posted a link with dipstick measurements for all stovebolts. You could probably buy one that's close and cut it and mark it to fit.
1950 Chevrolet 3100 (Ol' Roy)
Curmudgeon
Curmudgeon
Originally Posted by EdPruss
Wrecking yard!
Ed
I needed a good laugh. Show me a wrecking yard that has one? You almost can't find those things at a pick n pull for later yeared vehicles, the easy grab stuff is gone.
And whats with the old car manual deal? Like the dealer stocks them? Sure.
I'll admit it's been a while since I've been in a salvage yard, but I find it hard to believe that people are just going around pulling dipsticks out of all the engines!
Now it's my turn to laugh!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I saw one on E-Pay but it was not cheap.
I can send you a link if you need.
1950 Chevy 3100
I don't need links to ebay, I don't do anything on ebay, since they changed things years ago. All I ever paid with is a money order, I don't think that is possible now.
I'm surprised no one is making them, as well as all the other impossible to find parts.
It is possible to pay with a money order on ebay. You just need to contact the seller, and work out the details. It's, of course, up to you, but I have personally found that having a paypal account is handy and convenient for other things too, besides ebay.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I have a dipstick listed in the freebies section. I think it came off of a 1948 big truck. You can have it if it will help you. Just pay shipping.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Note: the size/year of the truck/engine affect the length of the dip stick and the locations of the markings on the dip stick.
216 and 235 and maybe 261 dip stick dimensions are attached.
Quote
From Truckrolet:
I think (maybe headscratch ) what bouymaker was trying to do in posting the link to the manual, was to provide a resource listing that gives not only the "different" part numbers and applications for the variety of dipsticks (depending on the application/engine involved), but more specifically too help identify the correct dimensions (length) that applied for each of those items. The listing carries over to the next page in the manual (you can see just be clicking "Next Page") and each part is identified by a specific length. Different lengths equate to different level readings, yes/no/maybe so???
In my thinking, using that information would help make sure you get the correct length dipstick (one size does not fit all) for your application.
There have been a bunch of past conversations (Search the Site can direct you to them) about the correct dipstick length issue as it helps you make sure you are keeping the correct level of lube in your engine. Too low and damaged internals can ensue. Too much and you get blown seals and leaks galore. In both cases eeeek
Thanks to bouymaker for providing the useful info. thumbs_up
As others have already noted, a salvage/wrecking yard "may" be a source. You could also post an ad in the Swap Meet "Truck Parts Wanted" forum for what your looking for. Good chance some fellow Bolters could help you out.
Good luck on your search. wave
EDIT: TC beat me to the punch about the dimensions/length info with much a much more detailed list. grin
~ Dan
1951 Chevy 3 window 3100
Curmudgeon
Curmudgeon
The manual is called the 1929-57 Chevrolet Parts and Accessories Catalog and the part is located in section 1.516.
It's free. Gets easier to use over time and is rarely accessed by newbies before posting a question on Stovebolt.
Making one look at the link helps orient the viewer's mind to a source of information to improve their future searching skills.
It's kinda like on-line OJT to help others to help others with newbies questions.
"From Truckrolet:
And whats with the old car manual deal? Like the dealer stocks them? Sure."
http://chevy.oldcarmanualproject.com
Strongly suggest paying the $20 or whatever to get an actual copy of the correct shop manual for your truck and/or engine. The online resource is great….not as convenient as the real thing.
As for the dipstick…need to understand your goals here. Looking for a “correct” dipstick for some sort of high end restoration? Or just need something to get you by?
If it’s the latter, that dipstick chart posted above, a sharp file, and any old dipstick….will have you in business.
1951 3100
Thank you all for the help. I had a 70's 454 with a dip stick that fits, and is too long, I guess all the chev ones will fit, maybe not stock, but will do the job, with the correct markings and length. I have 3, 235's and no one piece dipsticks. The truck came with a coat hanger wire for a dipstick.
Shop manual? I have 55, 57, and 3, 58's and 59 supplement, I've had them for a long time will that work?
Dealer stocking parts? Sorry I didn't know they still had 1950's 235 parts, ignorant me.
