4 members (KEVINSKI, C10 - C90 Bill, Peggy M, JW51), 54 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#1477990 12/08/2022 12:07 AM
In the 1957 Truck Data Handbook, it shows the 4X4 option like it was a factory offering? I thought it started as a factory installed option in 1958? It also mentions that the gear set used in the front axle is made by Chevrolet same as the rear axle.
Truckrolet #1477997 12/08/2022 12:35 AM
1957 Chevrolet trucks destined for the NAPCO installation came from the assembly line with a riveted on crossmember for the NAPCO crossmember. It also came with a 5600 pound gross weight designation on the ID plate on the cab.
As far as where the NAPCO kit was installed, I don't know.
Truckrolet #1478009 12/08/2022 3:15 AM
1957 was the first year for the factory 4x4 offering, it was RPO-690.
The gear shift lever mounting plate/bracket was riveted to the frame at the factory...dealer installed units were bolted on. The transfer case is bolted to crossmember #2...this crossmember is riveted into the frame at the same place for both the two and four wheel drive units.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
