5 members (Ponchogl, walter74, 55shaker, ronsway, 1 invisible), 179 guests, and 9 robots.
Topics128,089
Posts1,056,138
Members48,435
#13091 05/16/2005 6:46 PM
Junior Member
Junior Member
I need to find out what spacer (edelbrock) to adapt an edelbrock #1406 to my stock 283 chevy intake manifold #3746829. I had the original carter wfb carb rebuilt by pros, however, it leaked terribly when I got it back so I kept it but am trying to get the beast running (60 Apache 20 4x4). Also I didn't know if I am going to big with this 600 cfm carb (ilo 500 cfm) or even a 2 bbl?
Squeeg
Hi squeeg62! Did you ever get that figured out? I'm actually trying to do the same exact thing, but can't find any info on it.
Looking forward to hearing what you ended up with.
Thank you for your help!
colby
colby
1952 Chevrolet 3100: Photos
Engine: 219 L6 to 250 L6 to 350 V8
Transmission: Borg Warner T56: 6 Speed (1994 Firebird)
1955 Chevrolet Bel Air
Engine: 265 V8
Transmission: Three Speed
Currently: Rebuilding Engine & Differential
1956 Chevrolet 6400
Engine: 250 L6
1958 Chevrolet Apache 3600
Currently: In Barn
1963 Chevrolet C10 Fleetside
Currently: In Barn
Hi Colby, Squeegy's post is from 17 years ago. I don't think you'll be hearing from him.
1950 Chevrolet 3100 (Ol' Roy)
He made 2 posts in May of 2005 and has never been back. Dead end!
Well, I tried. Thanks, guys!
colby
Engine: 265 V8
1956 Chevrolet 6400
Engine: 250 L6
Currently: In Barn
Currently: In Barn
Jegs, Summit Racing and all the rest sell adapters that will work. There are even universal adapters that have a couple of different bolt patterns and can be flipped over to fit different throttle plates. I bet someone on here knows exactly which one you need.
7
7 Offline
ColbyG, another inexpensive option would be to get a newer stock GM spread bore manifold designed for the Quadra-jet carb, the manifolds are a dime a dozen and you could get the manifold/carb set-up from any smallblock chevy. It would not be period correct but it appears as that is not a major focus.
Carburetion specialist
Colby - the original carb flowed approximately 380 CFM.
Jon
The Carburetor Shop
Colby, if the Edelbrock hasn't had any gasoline run through it yet, use if as a paperweight. One that's been run becomes a stinky paperweight. A 283 at 6K RPM and 100% volumetric efficiency (impossible) flows 490 CFM, so a 650 carb is WAY too much to run properly. "The ABC's of fuel systems- - - -Always Buy Carter!"
Colby - in 1957, Chevrolet used 2 different WCFB carbs on production engines, both passenger and Corvette, 2505s and 2555s. These numbers you will find in many references. They each flowed approximately 380 CFM.
But in 1957, Chevrolet also built racing 283's. These used Carter WCFB number 2493s. This number you MIGHT find in a few references, but it exists. And Carter published a flow number on this carburetor. It was also 380 CFM.
I have asked a number of folks this question, with absolutely no disrespect intended: does your 283 require more CFM than the racing engine built by Mr. Duntov?
Jon
The Carburetor Shop
Curmudgeon
Curmudgeon
"I had the original carter wfb carb rebuilt by pros, however, it leaked terribly when I got it back"
Sorry to be late to the discussion. It case others follow this topic in the future. Leaking where? Stock fuel pump?
