5 members (lumbersawyer, tclederman, TUTS 59, 39Master85, 1 invisible), 38 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
I have a 55-62 1/2 ton 3.90 differential that reportedly came from a 57. If possible, I would like to verify the year. there is no tag. Casting number on the pumpkin is 3707340. I believe this is for 55-62. stamped into the pumpkin is "A F1 21". Any links or info for these codes would be appreciated.
The date is stamped on the end of the pinion and ring gear, along with the tooth count on GM gears.
My Blog
Don,
According to info listed in a GM Master Parts and Accessory Catalog I was able to look at here Rear Axle Identification , the stamped "AF" code on you pumpkin appears to match a "3.90" code for 1955.2-1957 3100 and 3200 models (1/2tons).
I added a screen shot below with an arrow to help point out the tree in the forest of data on this page.
There is also a very old (2006) thread on this topic that discusses the "3707340" casting code. You can read more here: ID this rear axle
I am not familiar enough with the date code "1 21" that follows the "AF", but others with more experience will surely chime in with more details. Dave's reply above gives the most definitive way to confirm your "date" for the ring and pinion set in the pumpkin.
Hope this helps answer your question??? thumbs_up
~ Dan
1951 Chevy 3 window 3100
Rear Axle code "AF" was used from 1955 thru 1959...3.90 ratio, 3100 & 3200 Light Trucks.
The date code "1 21" = January 21st, the year is not stamped, only month and day.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
