2 members (Otto Skorzeny, KingG), 53 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#1476913 11/29/2022 8:05 PM
As I am driving down Saturday to try and get my 1950 5703 COE running, I had better find how what voltage the electrical system is and whether or not it is negative or positive ground.
How could I find out if the previous owner upgraded the electrical system. There is no battery in the truck.
The goal of getting it running (was a year ago) is to load it on and off the trailer rather than winching it up.
Thanks in advance.
Marty
7
7 Offline
You could check the generator/alternator for any nameplate, it should show voltage or a model number. Also see if there are any add-on gages that would indicate someone making modifications to the electrical.
AD Addict & Tinkerer
Chevys during that time period were 6 volt negative ground. If it was upgraded to 12 volts, there should be either a ballast resister feeding the coil or a coil that does not need a resister. The coil should be marked either 6 or 12 volts and if a resister is needed.
Phil
Project Journals
Stovebolt Gallery Forum
Marty,
The 1950 Chevy would have been Negative ground.
Another good indicator for deciding if 6V or 12V "generator" (if you can't read whats on the tag itself) - What color is the tag? Black tags were 6V. and red tags were 12V.
If it has an alternator and not a generator, could still be either or, but most likely 12V. Rating will be stamped into the housing somewhere.
Let us know what you discover. pix
~ Dan
1951 Chevy 3 window 3100
Headlights will be marked "12V" on the face if they are 12 volt, 6V lamps were not marked with their voltage...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
There will be no need whatsoever to have the charging system in operation for a short run. Disconnect the wires from the generator and regulator, and simply run temporary wiring to the ignition system. A well-charged battery will get the engine started and run it for several hours on nothing but battery power. I'd suggest running a new 12 volt coil and battery if all you intend to do is run the engine long enough to load the vehicle on a trailer. Use a ballast resistor between the battery and the coil if you choose, or just let the points carry the full voltage if you're only planning to run the engine for a few minutes.
Thank you guys, much appreciated!
Marty
All of the six volt Delco generator that I have seen have a band around where the brushes are. The twelve volt ones that I have seen do not. The original 6V Delco regulators have two screws in the top in diagonal corners. The 12 V ones have the cover screws , one on each side at the edge of the lower edge.
Hotrod's suggestion will give you the very best chance of success. Also when I am waking up an old engine, I like to power the coil from a separate source so the voltage doesn't get dragged down by the starter draw.
1951 1 Ton Completed
I have a six volt Delco generator that has no band around it, but has a stepped down rear case. But it's not original to the truck. It has "Wizard" stamped on it so it's likely a Western Auto rebuild. So that's not a definite way to tell the generator voltage.
