3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#1476157 11/22/2022 2:36 AM
GW
Offline
Does anyone know what I can do to reduce the play in my steering wheel?
I had the steering box all rebuilt, but it has not helped much.
I have a 1962 C20 pickup.
GW
GW #1476160 11/22/2022 2:57 AM
GW,
Have you checked the rest of your steering components???
Lots of other parts with wear can cause sloppy steering.
~ Dan
1951 Chevy 3 window 3100
GW #1476162 11/22/2022 3:14 AM
GW
Offline
Not recently. The whole front end was rebuilt a few years ago, but I'll check things out.
I thought the guys that removed the steering box and replaced it said that everything related to the steering looked good. I'll have to look into it more thoroughly.
GW
GW #1476208 11/22/2022 4:40 PM
Crusing in the Passing Lane
Get someone to jockey the steering wheel back and forth while you look at every joint(not running) to check for play.
Ed
GW #1476227 11/22/2022 6:39 PM
There is a screw with a lock nut on the steering box. You don't want to go too far with it, but I have tightened many over the years, including going much more than the recommended amount with no ill effects for many many miles.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
GW #1476675 11/27/2022 3:30 PM
GW
Offline
Thanks for the tips Bolters.
I'll check these out.
GW
GW #1476685 11/27/2022 6:14 PM
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
