7 members (MRMEROTH11, FAST55, Otto Skorzeny, Hotrod Lincoln, carbking, TUTS 59, Joe H), 86 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1476103 11/21/2022 4:56 PM
F Online: Content
How dose the window felt get attached to the channel? Is it glued or dose it have clips of some sort. When I helped a friend of mine do his 1950 F-1 we glued it in. I have never been able to find a service manual for this truck that shows how to do any of the body assembly.
1936 GMC T-14 restro-mod
FAST55 #1476130 11/21/2022 10:26 PM
On my '51, there were clips at the bottom rear of the window run channel, and small flat head sheet metal screws along the rear and top of the window opening. The division bar got small tubular rivets to hold the channel on the front. The clips might be available, but today's glues would probably do a quicker and easier job. You just need to be sure not to use too much glue.
This video shows the window channel installation on a '52. Your truck would be similar.
FAST55 #1476611 11/26/2022 4:29 PM
F Online: Content
Yea, I watched that video and the doors from 1936 to 1951 are some what different, I don't have the vent window just one piece of glass. But I think the info will help.
FAST55 #1476619 11/26/2022 5:32 PM
Curmudgeon
Curmudgeon
If the part you are talking about is the window channel lined with mohair (some call it felt), example:
https://www.steelerubber.com/flexible-run-channel-70-1108-57
You use these:
https://www.steelerubber.com/run-channel-clip-60-0374-58
Also, wherever you purchased from, give them a call and ask.
FAST55 #1476639 11/26/2022 9:58 PM
F Online: Content
I'll have to dig out the invoice from the vender I purchased them from and see what they say about the installation procedure.
FAST55 #1476730 11/28/2022 12:27 AM
I used some very small screws to attach the inner and outer strips on my '66.
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
