0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 338 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 338 | How dose the window felt get attached to the channel? Is it glued or dose it have clips of some sort. When I helped a friend of mine do his 1950 F-1 we glued it in. I have never been able to find a service manual for this truck that shows how to do any of the body assembly.
1936 GMC T-14 restro-mod
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | On my '51, there were clips at the bottom rear of the window run channel, and small flat head sheet metal screws along the rear and top of the window opening. The division bar got small tubular rivets to hold the channel on the front. The clips might be available, but today's glues would probably do a quicker and easier job. You just need to be sure not to use too much glue. This video shows the window channel installation on a '52. Your truck would be similar.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2012 Posts: 338 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 338 | Yea, I watched that video and the doors from 1936 to 1951 are some what different, I don't have the vent window just one piece of glass. But I think the info will help.
| | | | | Joined: Oct 2012 Posts: 338 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 338 | I'll have to dig out the invoice from the vender I purchased them from and see what they say about the installation procedure.
| | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | I used some very small screws to attach the inner and outer strips on my '66. | | |
