2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Have an original truck radio AD I think , plate on the case says model 986087 ca49 serial 61759 has a date line nothing on there. connected to 6 volt charger, no knobs but turned the on stem face lit up and hums like I remember 70 years or more years ago. looks clean inside,rectanguler buttons work says chevrolet on the face,single power wire with threaded bakelite fuse holder on the wire. Has a coax hole like a mid fifties car. Any ideas ?? Not gonna do any more to it till I hear more. mounting nuts and knobs are missing but will look one place for them. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Are you sure that number isn't 986067 ^ | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | truckernix It is 986067 punched it in wrong. What do you think ?? More in the morning gonna crash. Good morning, what was your take on those numbers ?? Any idea on the year of manufacture ?? Looks like it will fit 47 to 53.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Congratulations, that is the correct radio for a 1947 to 1953 Chev or GMC truck. It was made between 1947 and 1950. A newer model that looks almost identical when installed, was made from 1950 to 53 and either will fit all those years. You will notice that the rear cover is cut on an angle on the sides. It is often referred to as the "slant back" radio. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | truckernix Thank you for the information,since it hums,lights up with no smoke using 6v battery charger could I try an attenna to see if it might pick up something ?? Push knob buttons are pretty furry but inside looks clean. don't want to damage it,paint is pretty good,brown . | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well the big risk of course is powering it up but I guess we have passed that point. If there is no humming from the vibrator, you won't be able to get anything else by testing. If it is humming then connecting an antenna may show some results. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | truckernix Oh it hums like I remember from 1951 or earlier. | | |
