1 members (RLB), 113 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Hey all. I just got through with some rear suspension and brake work. Lots of the parts are similar to those used on the big bolts (springs, pins, shackles, etc...). I've also got an overload spring that rides on "perches" different from what I've seen before.
Peggy put this in my profile, so click below and take a gander.
Any thoughts on the originality of the auxiliary spring "perches"? Thanks.
A number of dimensions and parts appear to be similar or the same between a 3800 and a 4100.
I don't own a 4100 but do have two 3800s and both a 4400 and a 6400.
Some parts are very similar in appearace, and like I said already, I think there is some actual crossover on some parts in some years of 3800 and 4100. I draw that conclusion from stuff I've seen in restoration pack pages.
what they call perches are the flats places that are welded onto the top of the axle where the srpings ubolt on... the part your talkin about are the overload stops or rests.. at least thats what i call them...those look like ya said..angle iron, the originals were curved where the overloads rode. on something that always carried a heavy load it wasnt unusual to wear out that overload spring..or the stops..... its just friction with no grease... looks like someone "fixed it" im surprised they werent just welded on fixed..... i can look,,, ive got a pair off a 59 one ton that im not gonna use....if you think ya need exact originals....\
oh....and P.S.
one tons are big bolts... hehehe..
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
Weed,
Thanks for correcting me. Overload stops makes sense... I just didn't know what the word was.
They are angle iron, and they where welded on... but after they where originally bolted on and one of them had broke. I replaced it with angle iron.
Add to that the fact that there where only 3 holes attaching these to the frame, not the 4 that I've seen with other GM stops of the same era. I wonder if mine originally had overload springs? Either way I'm keeping em and I like it! Thanks for the offer for the "original stops" but mine will work just fine and I don't want to drill more holes through the frame.
The PO of mine halled asphalt and gravel with it after he no longer used it as a grain truck. Now that's a big bolt!
