6 members (1955 1 Series, 53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost), 100 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
Besides the screws on the dash what switches really need to be removed. Thanks Stan
Sir Searchalot
Sir Searchalot
If you are talking about wanting to remove the gauge cluster/speedo cluster and are asking what switches need removed, you must have a 64, 64 or 66. In that case pull out the cluster, the "switches" will have some service loop to access the back of the switches. If they have connectors or removable terminals, unplug them. If you want to leave them attached to the wiring, they should be removable out the rear of the panel by removing a nut/knob. Then they can be left hanging. Examine the situation. There can be aftermarket owner added things and wiring methods.
On 60-63 there are no switches mounted to the cluster, just gauges, lamps and speedo.
I do have a 66 C20. For some reason the light switch part of the cluster doesn't seam to lift up I was thinking the switches were holding hings up. Must be something else, I will have another look. Thanks, Stan
Sir Searchalot
Sir Searchalot
Don't forget to disconnect neg battery cable.
Headlight switch has a push button underneath. Pull knob shaft out to "on" position, depress button and pull shaft out front. Might take several tries and pull methods. Then take switch off rearward.
Socket Breaker
Socket Breaker
This should help you out:
Removing the Instrument Cluster on a 1966 C10
-Woog
