0 members (), 94 guests, and 4 robots.
Topics128,271
Posts1,058,313
Members48,485
#1476226 11/22/2022 6:37 PM
Pick up a set of 4 ,16x7 steel wheels, what is a good size tires to run on these? 53, 3100..thanks
1953 with a 216
Luray #1476231 11/22/2022 6:54 PM
Before buying tires, check to see if those wheels will fit on without interference. The stock wheels on a 53 3100 were 16 x 4.5 and yours are twice as wide.
The wheels on my F250 are 16x7 and I run 265/75R16 tires, but they're BIG. An alternate size is 235/85R16.
Luray #1476232 11/22/2022 6:56 PM
They fit .
1953 with a 216
Luray #1476234 11/22/2022 7:08 PM
I'm wondering if tires that big would fit though. You might experience rubbing. Some guys run 215/XX R16's (don't remember the aspect ratio) but they usually run them on the stock wheels.
Luray #1476235 11/22/2022 7:20 PM
Yes ,truck came with 235 /75/15 , wheels, I converted to disk up front. Was told to run a 215 /50 /16 tire.
1953 with a 216
Luray #1476238 11/22/2022 8:11 PM
You might want to consider a taller (larger number) aspect ratio. That 215 tire would be a bit smaller than stock, which would reduce your top speed somewhat.
A 225/70R16 would be 28+ inches diameter vs ~25 inches diameter for the 215/50. Either would fit on your 7" wide rims. Or a 215/65R16 would be 27" dia.
Luray #1476242 11/22/2022 8:25 PM
1953 with a 216
Luray #1476245 11/22/2022 8:39 PM
I hope you have power steering because turning the wheel with those fatass tires is a chore when you're moving. It's nearly impossible when you're not.
1950 Chevrolet 3100 (Ol' Roy)
