| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2022 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 29 | Besides the screws on the dash what switches really need to be removed. Thanks Stan | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you are talking about wanting to remove the gauge cluster/speedo cluster and are asking what switches need removed, you must have a 64, 64 or 66. In that case pull out the cluster, the "switches" will have some service loop to access the back of the switches. If they have connectors or removable terminals, unplug them. If you want to leave them attached to the wiring, they should be removable out the rear of the panel by removing a nut/knob. Then they can be left hanging. Examine the situation. There can be aftermarket owner added things and wiring methods.
On 60-63 there are no switches mounted to the cluster, just gauges, lamps and speedo.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2022 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 29 | I do have a 66 C20. For some reason the light switch part of the cluster doesn't seam to lift up I was thinking the switches were holding hings up. Must be something else, I will have another look. Thanks, Stan | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't forget to disconnect neg battery cable. Headlight switch has a push button underneath. Pull knob shaft out to "on" position, depress button and pull shaft out front. Might take several tries and pull methods. Then take switch off rearward.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | |
