4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 20 | Does anyone know what I can do to reduce the play in my steering wheel? I had the steering box all rebuilt, but it has not helped much. I have a 1962 C20 pickup. GW | | | | | Joined: Sep 2009 Posts: 5,844 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,844 | GW,
Have you checked the rest of your steering components???
Lots of other parts with wear can cause sloppy steering.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2010 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 20 | Not recently. The whole front end was rebuilt a few years ago, but I'll check things out. I thought the guys that removed the steering box and replaced it said that everything related to the steering looked good. I'll have to look into it more thoroughly. Thanks GW | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Get someone to jockey the steering wheel back and forth while you look at every joint(not running) to check for play.
Ed
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | There is a screw with a lock nut on the steering box. You don't want to go too far with it, but I have tightened many over the years, including going much more than the recommended amount with no ill effects for many many miles. | | | | | Joined: Jul 2010 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 20 | Thanks for the tips Bolters. I'll check these out. GW | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
