4 members (Bill Hanlon, Otto Skorzeny, gswbbc, dt235sd), 83 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1476053 11/21/2022 1:10 AM
Pulled this engine out of 1954 1 1/2 ton I believe its a 235
The numbers by the starter conv1 j1856
The numbers beside distributer TT023A
Block casting 3837004
http://devestechnet.com/Home/CastingNumbers
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/512127/casting-numbers.html
Suggest you also get the cylinder head casting number, on intake side outside of the valve cover... I have 2 engines with casting number 3837004. Both are 235s, but I understand that this block could also have been used as a 261 in later years. The conv # indicates a casting date of Oct.18, 1956. You may have an error in reading the distributor pad stamped number... the T indicates Tonawanda engine plant, the A at the end indicates a 3 speed car engine originally. I suspect that the 2nd digit is not a T but a 1, so T1023A would be Tonawanda built Oct. 23 for a 3 speed passenger car. Others may correct me (okay) or have more info.
1953 Chevrolet 3100
J1856 = Date of casting (October 18, 1956
Engine Code T023A
T = Tonawanda Engine Plant...Not sure why you show two "T"s
02 = Month (February)
3 = Day
A = Regular 235, passenger car
Lacking a serial number this engine had to be assembled in 1957.
Casting number 3837004 is a 235 block used from 1955-57
Mike B smile
EDIT, Steve J makes a good point on the second T...if it's a one then my above date code is wrong...
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
