5 members (55shaker, Ponchogl, cmayna, Shade Baby, Leo), 175 guests, and 2 robots.
Topics128,114
Posts1,056,282
Members48,439
Can I simply swap the wires on the 2 gauge terminals?
Needle moves very slightly when ignition is on, drops when it is off. Tank should be about 1/3 full.
My ammeter works backwards but provides the necessary information.
Mike Barnes
1950 GMC 1-ton pickup
Gauge reads full with key on when the sending unit wire is removed.
Mike Barnes
I found the gauge works as it is, no need to swap the wires. Also found my new sending unit float is full of fuel!
Mike Barnes
Sending unit and gauge works, just have a split in the float.
Info that may help others with a 6v system: with sending unit wire removed you get 30 ohm from the wire to ground. With the same connection you get 3v with the ignition switch on. As stated elsewhere, sending unit reads 0 ohm with empty tank and 30 ohm with full tank.
Mike Barnes
Insomniac
Insomniac
Don't forget fuel gauge voltage reducer when switching from 6 to 12 v.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Crusing in the Passing Lane
Might as well switch the ammeter wires to get correct reading, less confusing.
Ed
