7 members (Woodcmiami, Jon G, 2-Ton, Pre '68 Dave, Rusted Nut, 55shaker, Bill Hanlon),
117
Mod | | | Forums66 Topics128,109 Posts1,056,260 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hello,
Does anyone know a place I can buy new upper hinges for the clam shell upper door? If not, does anyone have pictures they could send of what they look like?
Russ Sweet | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | *** Russ, You are searching for one of the hardest to locate items for the Suburbans. I've been searching for upper clamshell props for my 53 for a couple of years & have not run accross a single prop must less a pair. I don't know if your needs are the same as a 1953 *** *** probably not. But if I run accross one or a pair that might fit your suburban I will let you know. | | | | | Joined: Feb 2016 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 9 | I have some I can send you pics | | |
