4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
Hello,
Does anyone know a place I can buy new upper hinges for the clam shell upper door? If not, does anyone have pictures they could send of what they look like?
Russ Sweet
*** Russ, You are searching for one of the hardest to locate items for the Suburbans. I've been searching for upper clamshell props for my 53 for a couple of years & have not run accross a single prop must less a pair. I don't know if your needs are the same as a 1953 *** *** probably not. But if I run accross one or a pair that might fit your suburban I will let you know.
I have some I can send you pics
