4 members (3B, Gray_Ghost, Otto Skorzeny, TGP), 86 guests, and 2 robots.
Topics128,162
Posts1,056,944
Members48,458
#1475131 11/13/2022 10:22 PM
The cancelling cam I have looks identical to all those available from the usual suspects, but it does not have the reach to actually catch and trip the the little levers that will cancel the signal. If my measurements are accurate, it needs an additional 1/2 inch of diameter before it would work. Am I missing something? Is there a trick to making these things work? Sure hope someone has run into and corrected this problem and can offer some suggestions. Thanks for any ideas.
Maxine,
Can you post pictures of your cancelling cam set up???
Best way for folks to maybe help determine if something is incorrect or missing.
~ Dan
1951 Chevy 3 window 3100
Maxine Don't you move the switch up or down the column to adjust the cancelling ?? The ones I've had the wheel would have a flat spot from sitting in one spot for years maybe.
