| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 32 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 32 | The cancelling cam I have looks identical to all those available from the usual suspects, but it does not have the reach to actually catch and trip the the little levers that will cancel the signal. If my measurements are accurate, it needs an additional 1/2 inch of diameter before it would work. Am I missing something? Is there a trick to making these things work? Sure hope someone has run into and corrected this problem and can offer some suggestions. Thanks for any ideas. | | | | | Joined: Sep 2009 Posts: 5,983 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,983 | Maxine,
Can you post pictures of your cancelling cam set up???
Best way for folks to maybe help determine if something is incorrect or missing.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Maxine Don't you move the switch up or down the column to adjust the cancelling ?? The ones I've had the wheel would have a flat spot from sitting in one spot for years maybe. | | |
