0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 559 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 559 | Got the truck driveable, made a few local 15-25 mile trips and she still slides out of high gear. Torque tube 3sp column shift. New pilot is snug. New needles and bearings. Good looking gears. New rear bushing. Bell tight to engine and trans. Some wear on the synchronizers as they need a smooth/easy shift to 3rd or down to 2nd. 2-1/2 pt period Amoco 90wt. Feel full shift to 3rd but also feel it easing out as I drive. Thoughts? Jethro.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Jul 2000 Posts: 2,208 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,208 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2019 Posts: 4,516 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,516 | Is the oil you used 90wt mineral oil? If your using a modern oil, it may be too slippery for the synchro’s to work properly. Here is a thread explaIning the importance of using the correct oil. https://www.stovebolt.com/ubbthread...752/re-transmission-oil.html#Post1452752
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2022 Posts: 559 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 559 | I'll get some from tractor supply or napa. Probably jack the rear up and run some diesel in it for a few minutes to clean it out if that sounds reasonable. Thanks. Jethro.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Oct 2021 Posts: 6,970 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,970 | I don't think you have to wash it out with diesel. Just drain it well and fill it up with the right stuff.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Once the synchronizer matches the gear speeds and the shift collar engages, the lube won't make a difference. Slipping out of gear is a result of wear on the small male teeth on the input shaft that the synchronizer sleeve engages, and the corresponding female splines on the synchronizer drum. If there's any taper wear at all on those mating pieces, the sleeve won't stay engaged on the back end of the input shaft for direct drive. Both pieces will need to be replaced. Jerry
| | | | | Joined: Jun 2022 Posts: 559 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 559 | Well, I drained the trans and the nice-looking Amoco 90wt had a caramel foam on top. Filled it with NAPA 90wt mineral and after slipping out once a mile down the road it didn't slip out again on a 12 mile ride. Drove it again later and it stayed in 3rd the whole way. Hopefully the change did the trick. Think I'll dump the rest of that Amoco down a groundhog hole.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2019 Posts: 4,516 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,516 | Well, I drained the trans and the nice-looking Amoco 90wt had a caramel foam on top. Filled it with NAPA 90wt mineral and after slipping out once a mile down the road it didn't slip out again on a 12 mile ride. Drove it again later and it stayed in 3rd the whole way. Hopefully the change did the trick. Think I'll dump the rest of that Amoco down a groundhog hole. Good to hear that the issue seems to be solved. Additionally, any place that changes oil will accept oil used for maintaining vehicles or at least tell you where you can dispose of it. No need to dump it into the ground.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Oct 2021 Posts: 6,970 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,970 | I think he was joking about the groundhog hole.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Jetro in VA Don't do the groundhog hole,it'll contaminate the ground water | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Fire ant nests are a lot more suitable places to dispose of used oil- - - - -those nasty little critters deserve all the lubrication they can get. I've been known to park an idling Diesel tractor over a big fire ant mound and create a little bit of a fuel leak by loosening a return line on an injector. Jerry
| | | | | Joined: Oct 2021 Posts: 6,970 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,970 | I'm pretty sure he was joking about that. Everybody knows that pouring it down a storm drain is the best way to get rid of used oil.
