5 members (66flea, WICruiser, 68ironhead, TUTS 59, 1 invisible), 105 guests, and 3 robots.
Topics128,081
Posts1,056,321
Members48,442
First 2 pictures are passenger side corner patch. Pictures 3 and 4 are driver side corner patch. Both are just "cleeco'd" in for now. The passenger side looks like it will fit without major tweeking. On the driver's side, I had to make a couple of "relief cuts" to make the corer patch conform to both he curvature of the original cab back and also to the patch I did to the driver side, lower hinge pillar. Now for the question (see pictures 2 and 4): I do not like the "incompleteness" of where the corner patches intersect with bottom of the hinge pillars and the side and bottom of the rocker panel. I am thinking that I am going to weld extensions onto the corner patches so that they cleanly envelope the entire bottom of the hinge pillars and also weld cleanly to the side and bottom of the rocker panels. Advice? Reaction? Comments? As always, thank you for the guidance.
1952 Chevy 3100
Fill it! But keep in mind, most low points on these body's need, or I should say, have a moisture drain. They usually get filled with mud then everything rots any way, but I vote for fill it and don't allow water to splash up in there.
Definitely fill those gaps. The original corners had a louver style opening at the bottom as a drain point. It was aimed at the back to keep splashing out. I’d recommend having something to let water out.
