2 members (sron48, Gray_Ghost), 78 guests, and 3 robots.
Topics128,078
Posts1,056,052
Members48,433
#1474471 11/08/2022 11:05 PM
I know I'm asking the impossible but anyone know of a replacement bearing part# for this 16 spine inner hub bearing.
What truck does it go on? That info might help.
It's on a Chevrolet 1/2 ton suburban with the napco 1/2 ton front Axle assembly.
That caged needle bearing should be a standard item any industrial bearing supply facility should be able to supply. Is there a part number on the race anywhere? You might need to pull the bearing assembly out of the housing to find it.
Check and see if it is one of these:
AXLE HUB ASSEMBLY Timken LM 501349 Outer Bearing 2 Required
Timken LM 501310 Outer Bearing Race 2 Required
Timken LM 603049 Inner Bearing 2 Required
Timken LM 60301 Inner Bearing Race 2 Required
CR (Chicago Rawhide) Inner Oil Seal 2 Required
don
No there's no part# on either side. Ordered and installed those hub bearings. Thanks for the parts# Don.
Took the other side hub apart today and found the part# for the needle bearing for the locking hub. It's a Torrington B - 2610. It looks like it's available on line.
Thanks sub57, I've added it to my list.
dons
