| | | Forums66 Topics128,078 Posts1,055,935 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2022 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 29 | I need to remove the fuel tank too clean it. It looks like it should come out without too many problems. Can it be done without removing the seat? Thanks Stan | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | You might be able to work it out with only the seat back removed. But I believe it will be worth your time to remove the entire seat. The tank needs to wiggle some to get the neck below the cab skin.
If you get it out with the seat still on the floor let us know. I have always done it with seat removed, but I am interested in what you experience. | | | | | Joined: Jul 2022 Posts: 10 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 10 | My son an I just replace my 66 C20's tank. I actually put the thank alone, then my son tied evrything together. It can be done without to much trouble. Watch out for the gas gauge wire. Put the neck on loose and place the tank. Adjust the neck so it doesn't stick out to far. Pull the tank again and tighten the neck, the put the tank in and tie it down. Good luck and stay safe. | | |
