2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Good afternoon.
Thinking of adding a set of the factory installed bullet brake lights to a 49 panel.
Have no idea where to drill the hole.
Any help is appreciated.
Thanks.
Leo Offline
Moderator
Moderator
I added the bullet shaped lights to my 1953 panel. Mine were off a 1938 Oldsmobile wagon. They were almost exactly the same, the mounting holes were different. Just be sure that when the rear doors are open 180°, they won't hit the lights.
All, considering adding the dealer installed bullet shaped tail lights to a 49 panel. These are the ones offered by Jim Carter. Only problem is I have no clue about the correct location of the mounting hole. Does anyone have dimensions and/or pics?
Thanks.
You didn't like my previous response?
I guess he didn’t read your very informative response to his other identical thread.
Sorry didn’t see it
Patience is a virtue
I have none of it
Thanks guys
I’m getting old
Forgot I had already asked the question
Thanks again
Leo Offline
Moderator
Moderator
There is a template avaliable. I think Tim has one. As I mentioned in the other thread, be sure the doors don't hit the lights when opened 180°. If I recall, the lights should be 4 inches above the belt line.
I cannot find the template; however, here are installation instructions.
Here is a diagram with measurements to help locate the template. I'll be adding lights to my panel truck too.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Excellent, Walter.
Thanks again guys
Does anyone have pics of what they did for an access panel cover
I’m referring to the hole that apparently needs to be cut in the inner panel to install nuts to fasten lights and run wire
Hate cutting up this perfect old Sheetmetal
Jack
There's actually an access hole, underneath the cardboard cover, that allows you to reach in and do what you need to do.
Thank you
Found them thanks under the oh so attractive 1970s paneling
Beware of the templates
The ones I got didn’t print off in the correct scale
Tried to tell Jim Carter
Not sure they heeded my message
I redrew
Assuming I drew it right am happy to share
I redrew
The one that Tim posted is pretty close. I printed it out from the PDF. It's 1/8" short in the horizontal dimension, but on the money vertically. Probably not enough to worry about, but you could hold the point back 1/8" from the door edge and be right on the money.
I got some axle bumpers from Jim Carter that didn't fit quite right and let them know, but never got a response of any kind.
Haunting the SBP since 2001
Those ad on lamps are great but just my opinion, they look like eyesores when mounted up near the body beltline .
{ as the original template suggests }
They look much better when mounted lower on the body...
