Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 93 guests, and 5 robots.
Topics128,281
Posts1,058,469
Members48,490
H Online: Content
I'm looking for a source for the male thread nut that attaches the rocker arm oil line on a 216 or an early 235 to the oil connector. It's a 3/16" diameter one-time use fitting that crimps itself onto the oil line the first time it's tightened. The same nut is used on the oil line that goes through the water jacket where it exits the block on the driver's side, along with a female fitting that threads into the block. It's included in the "kit" that some of the resto-ripoff places sell to replace the through-block oil line, but it's a lot less expensive to buy the copper tubing and the fittings in bulk and fabricate the line from scratch. Thanks in advance!
Would you recognize the nut if you saw it? If so, try looking through Mr. G's Fasteners pictures on the website. I think his images are life size.
If you can't find it, give him a call. He's always been very helpful for me.
Mr. G’s Enterprises Automotive fasteners, of all types
5613 Elliot Reeder Road
Fort Worth, Texas 76117-6013
817-831-3501 or 817-838-3131
https://mrgusa.com/
1950 Chevrolet 3100 (Ol' Roy)
I think this is what you’re looking for.
Link
H Online: Content
That's it- - - - -thanks! I'm coaching an engine builder over in Virginia through his first spray-oiler rebuild on an early 1950's 235, and somebody had lost or damaged a few parts before he got involved in the job. He's got the short block assembled with all the right clearances and the spray tubes aimed- - - - -now it's time to button things up and get it running.
Here's a link to the complete assemblies, male and female parts.
https://www.mcmaster.com/catalog/128/209
Weatherhead 6100x3.....Napa keeps a lot of Weatherhead fittings.
Mike
1951 3100 5 window
