| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I'm looking for a source for the male thread nut that attaches the rocker arm oil line on a 216 or an early 235 to the oil connector. It's a 3/16" diameter one-time use fitting that crimps itself onto the oil line the first time it's tightened. The same nut is used on the oil line that goes through the water jacket where it exits the block on the driver's side, along with a female fitting that threads into the block. It's included in the "kit" that some of the resto-ripoff places sell to replace the through-block oil line, but it's a lot less expensive to buy the copper tubing and the fittings in bulk and fabricate the line from scratch. Thanks in advance! Jerry
| | | | | Joined: Oct 2021 Posts: 6,822 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,822 | Would you recognize the nut if you saw it? If so, try looking through Mr. G's Fasteners pictures on the website. I think his images are life size. If you can't find it, give him a call. He's always been very helpful for me. Mr. G’s Enterprises Automotive fasteners, of all types 5613 Elliot Reeder Road Fort Worth, Texas 76117-6013 817-831-3501 or 817-838-3131 https://mrgusa.com/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,069 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,069 | I think this is what you’re looking for. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | That's it- - - - -thanks! I'm coaching an engine builder over in Virginia through his first spray-oiler rebuild on an early 1950's 235, and somebody had lost or damaged a few parts before he got involved in the job. He's got the short block assembled with all the right clearances and the spray tubes aimed- - - - -now it's time to button things up and get it running. Here's a link to the complete assemblies, male and female parts. https://www.mcmaster.com/catalog/128/209Jerry
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Weatherhead 6100x3.....Napa keeps a lot of Weatherhead fittings.
Mike
1951 3100 5 window
