4 members (Guitplayer, asilverblazer, Sjm, Wally / Montana), 98 guests, and 2 robots.
Topics128,260
Posts1,058,321
Members48,485
Looking for brake line routing diagram for 6 lug cpp disc brake conversion for front and drums at back.
1953 with a 216
Curmudgeon
Curmudgeon
Crusty Old Sarge
Crusty Old Sarge
This is not from CPP but from Speedway, it may help though.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
That's how mine is plumbed.
1936 GMC T-14 restro-mod
Only issue with that diagram is that it does not show the mstr cylinder orientation, if it’s a F–d style like speedway offers the fronts are piped closest to the mounting flange, if it’s a Gm corvette style manual master, it’s A-typical, the rears pipe closest to the mounting flange….
Trying to get a proper answer on the gm master is painful, so-called experts weigh in both ways, everywhere you look
Let’s see If there is any discussion on this………
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
