| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 33 New Guy | | New Guy Joined: Mar 2006 Posts: 33 | I'm thinking it might be nice to improve the brakes on my 1950 4100 a bit; I'm hauling some heavy loads and sometimes it feels like there's more pedal travel than I'd like. The truck has an odd mixture of parts on it. The wheels are 16", 8 lug. Grigg helped me identify the rear axle as a Dana 70. The front drums look like 12" the rears 14", and there's a relatively newer looking master cylinder and power booster on the fire wall. When I had the inspection done, there looked to be a fair amount of meat on the shoes, and not much by way of available adjustment at the shoes. I'm wondering if I may not be using the full length of the master cylinder, and I could use a longer rod, and/or maybe attach the rod further down the pedal to get a bit more travel. Or maybe a bigger bore master cylinder might help. Barring that, I can get a disc brake conversion kit for the Dana 70 rear fairly easily, but I'm not sure what I could do to upgrade the fronts (I think it was Grigg that was suggesting it might be a custom fab job to convert the fronts to discs). Any ideas, input on thngs that worked well, or poorly, would be appreciated. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Be sure to bleed the brakes before going in to anything complicated on the lots of pedal travel thing. it could be just a little bit of air.
My next guess is that you have a master cylinder with too small a bore for the wheel cylinders. Assuming you have 3/4 and 1 ton stuff I would expect to see a MC bore around 1" to 1.25"
Then you may look at the linkage, unless it looks ____ed up / unsafe to start with, then fix that first.
Start simple and go from there.... | | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | Something else that you may to check out are the drums. It might be possible that they could have been turned so many times that they are now way oversize on the inside diameter of the drum.
I am not sure, but I can think of at least a couple of theories that could cause oversize drums to reduce braking performance. Not to mention that if they are extra thin, it's possible they could cause catastrophic brake failure.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | True, oversize drums can actually swell when perssure is applied and cause a soft pedal. Then they break and the pedal gets really soft. | | | | | Joined: Mar 2006 Posts: 33 New Guy | | New Guy Joined: Mar 2006 Posts: 33 | I guess another possibility is spongy rubber lines; I'll have a look at the lines, too. | | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | May be check that the shoes are adjusted and nothing is stuck. Sounds like its worth getting right. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Mark I'd love to see some photos of this truck! Can you post some somewhere? Or email them to me and I'll post them where they are visible to anyone you want to see them.
I'd like to see the front fenders, hood and grill to see if they are the same as a 3800 or a 4400. Then I'd like to see the fit of the front wheels in the fender wells.
And I'd like to see how the rear axle is mounted under the rear of the truck.
I hope the pictures aren't too much to ask. I'm really interested in what they look like.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2006 Posts: 33 New Guy | | New Guy Joined: Mar 2006 Posts: 33 | Finally got back to this. Tried the simpler things first. No air in lines, adjustment looks OK, shoes seem OK as do drums. So we tried swapping the old MC (1 3/4) with the biggest bore substitute we could find that would fit on the booster; that was 1 7/8". Unfortunately that gave no noticeable improvement (of course all I guess you'd expect would be a decrease in pedal travel to around 87% of what you had before, which isn't a whole lot). So I'm still looking for suggestions. Maybe the key is figuring out what the front axle/brakes came from. Any ideas would be appreciated. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Mar 2006 Posts: 33 New Guy | | New Guy Joined: Mar 2006 Posts: 33 | I've got the front brakes off now. The friction material measures roughly 1.75" x 11" (actually a bit under 11"). I'm thinking that this is consistent with the front brake for a 3600. I see that the front for the 3800 is nominally listed as 12" x 2". It almost looks like you could use the 12" x 2" shoes instead of the 11" x 1.75", simply by turning the drum and extra 0.250" deeper (but retaining the old backing plate, wheel cylinders, drum). Does anyone know if this more-or-less drop-in replacemen/upgrade is possible?
Thanks, Mark | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your figures don,t add up. You can,t go cutting masive material off drums to modify things. If your rear are the 2 wheel cyl. type they have 2 adjustments. If you get the adjustments right & all the air out of the system you will have a good pedal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | He has at least a newer Dana 70 rear, and perhaps a different front. I agree, don't modify drums. The difference in 1/4" of brake lining width should not be a significant improvement unless you are pushing your brakes to their limits stopping your truck now. Doesn't sound like it's worth the aggravation to do anything with them to me.
I agree, if you have all the air out of the system and good drums, lines, and properly adjusted shoes you will have a good firm pedal. Could it be possible that someone has a wheel cylinder installed upside down and the bleeder screw is not on top, therefore trapping air in the cylinder? If that checks out OK then I would bleed the brakes several times and with different methods trying to be 100% certain the air is out. Try pumping the brakes to bleed, and also try a vacuum bleeder.
Grigg | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Can you adjust the brakes to where the wheel won't spin without using the pedal? | | |
