3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
Today I did a test drive - after sitting for 10 years - with the 41 (62 rear end) and got a combination of a "clonck" and something like a short ratchet sound while breaking.
Brakes are working okay (not great though). I was filling up the fluid and bleeding them a week ago - any ideas?
Thanks, Frank
3B Offline
Hy Stovebold6, there could be rust on the drums braking surface, it will take a few stops to wear the rust away, good luck.
Turned out the main cylinder needs an overhaul.
Curmudgeon
Curmudgeon
Most brake fluids, typically used in older vehicles, are hygroscopic (absorbs moisture).
Rust can develop in the master cylinder and migrate through the brake system.
At minimum, I would flush the whole system of old brake fluid.
A thorough brake job would include a cleaning or replacement of the wheel cylinders.
