0 members (),
87
0
Mod | | | Forums66 Topics128,108 Posts1,056,566 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | Trying to decide if I have a problem or not in my 235. Seems to be running a touch hot IMO. It is a recent rebuild bored .080, otherwise I would consider it pretty much a stock setup (new rings, pistons, lifters, rods and oil pump). It runs about 185-195 degrees at the temp sender (checking with a laser pointer thermometer) after idling in the driveway for 25 minutes on a ~50 degree day after swapping the stock radiator to an aluminum one. Before radiator swap I was getting up around 212 degrees after about 15-20 minutes. I have been through EVERYTHING multiple times except for pulling the head back off to make sure no ports were clogged. I even went as far as filling old radiator and block w/ evapo rust, pulling water pump and block drain and going to town with a water hose and compressed air to flush everything multiple times. I am running a 160 deg t-stat w/ an 1/8th in hole drilled in it.
Note: this is in my '50 3100. I have used the 235 guy's water pump adapter plate to relocate center of the radiator. The fan blades are 1/2 to 3/4 of an inch away from the radiator.
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Is the coolant boiling? If not, the engine isn't overheating. What does the temp do at highway speed, or at fast idle with a fan blowing on the radiator? Jerry
| | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | Still getting my truck together and haven't really driven it on the road other than up and down the street. We live on a little bit. It would puke a little bit of coolant with the original radiator and cap. . Not getting any with the new one.
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | The new radiator will allow you to run a pressure cap that raises the boiling point 3 degrees for every pound of pressure. Then the condition of heater core becomes the limiting factor. Original cores will only handle around 4-7 PSI, less if they're in poor condition. Upgrade the heater as well as the radiator and you'll be able to run the pressure up to 12-15 PSI or so and not worry about boil over below 240 degrees or so. Jerry
| | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | Yeah the new radiator came with a pressure cap. I just wasn't sure if it was running too hot at the current temperatures I am seeing. Just trying to make sure I'm not jeopardizing my newly engine
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | A 1950 truck would have been manufactured with a "zero pressure" cooling system. Any radiator cap over about a 4 pound rating is going to put your heater core at risk. You're much more likely to put the engine at risk from a burst heater core than you will by letting the temp rise above 200 on occasion. Modern engines don't even turn an electric fan on below 220, so going a little above the theoretical boiling point with no pressure isn't as disastrous as some people think. Jerry
| | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | Gotcha. I did notice the difference in caps, never thought about the heater core but I haven't hooked it up yet anyways. Thanks for the heads up.
