5 members (lumbersawyer, Otto Skorzeny, Southerntruck, Bill Hanlon, 1 invisible), 124 guests, and 3 robots.
Topics128,096
Posts1,056,483
Members48,444
#1472771 10/27/2022 8:23 PM
Trying to decide if I have a problem or not in my 235. Seems to be running a touch hot IMO. It is a recent rebuild bored .080, otherwise I would consider it pretty much a stock setup (new rings, pistons, lifters, rods and oil pump). It runs about 185-195 degrees at the temp sender (checking with a laser pointer thermometer) after idling in the driveway for 25 minutes on a ~50 degree day after swapping the stock radiator to an aluminum one. Before radiator swap I was getting up around 212 degrees after about 15-20 minutes. I have been through EVERYTHING multiple times except for pulling the head back off to make sure no ports were clogged. I even went as far as filling old radiator and block w/ evapo rust, pulling water pump and block drain and going to town with a water hose and compressed air to flush everything multiple times. I am running a 160 deg t-stat w/ an 1/8th in hole drilled in it.
Note: this is in my '50 3100. I have used the 235 guy's water pump adapter plate to relocate center of the radiator. The fan blades are 1/2 to 3/4 of an inch away from the radiator.
Jason
Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.)
1950 Chevy 3100
Is the coolant boiling? If not, the engine isn't overheating. What does the temp do at highway speed, or at fast idle with a fan blowing on the radiator?
Still getting my truck together and haven't really driven it on the road other than up and down the street. We live on a little bit. It would puke a little bit of coolant with the original radiator and cap. . Not getting any with the new one.
Jason
1950 Chevy 3100
The new radiator will allow you to run a pressure cap that raises the boiling point 3 degrees for every pound of pressure. Then the condition of heater core becomes the limiting factor. Original cores will only handle around 4-7 PSI, less if they're in poor condition. Upgrade the heater as well as the radiator and you'll be able to run the pressure up to 12-15 PSI or so and not worry about boil over below 240 degrees or so.
Yeah the new radiator came with a pressure cap. I just wasn't sure if it was running too hot at the current temperatures I am seeing. Just trying to make sure I'm not jeopardizing my newly engine
Jason
1950 Chevy 3100
A 1950 truck would have been manufactured with a "zero pressure" cooling system. Any radiator cap over about a 4 pound rating is going to put your heater core at risk. You're much more likely to put the engine at risk from a burst heater core than you will by letting the temp rise above 200 on occasion. Modern engines don't even turn an electric fan on below 220, so going a little above the theoretical boiling point with no pressure isn't as disastrous as some people think.
Gotcha. I did notice the difference in caps, never thought about the heater core but I haven't hooked it up yet anyways. Thanks for the heads up.
Jason
1950 Chevy 3100
