8 members (66flea, asilverblazer, J Lucas, Otto Skorzeny, tclederman, Hotrod Lincoln, klhansen, 1 invisible), 136 guests, and 3 robots.
Topics128,185
Posts1,057,294
Members48,467
#1472505 10/25/2022 10:56 PM
Anyone know of a rebuild kit for this transfer case. Someone in a post mentioned a ford kit that was 99% the same parts gears and all, but didn't say the model # , part# or year.
GM used the Spicer 23, Ford used Spicer 24. Output shaft on opposite side. Torque King has parts. I think all the parts are the same.Jim Carter used to have these kits, I think I got one from them. Might want to call them. You can get bearing and seal numbers right off the parts.
Oh, and the NAPCO seal numbers still cross over the CR Industries, which is now something else. All the seal companies are pretty much consolidated.
CR is Chicago Rawhide, an old time seal manufacturer, and still exists as a subsidiary of SKF.
Thanks for the info guys.
The following are the part numbers I have: and yes I did order the Ford Spicer 24 rebuild kit and all the bearings fit (I think there were a couple extra.
don
These parts relate to Chevrolet & GMC 1/2
Ton 1957 (late), 1958 and 1959 for the Transfer Case (Spicer 23) and the
Front Axle Hub and Knuckle Assemblies.
TRANSFER CASE MRC 207-M/0009 Bearing & Race Assembly 2 Required
MRC 207-M Bearing & Race Assembly 2 Required
SKF 6307-ZNRJEM Bearing & Race Assembly 2 Required
SKF 6207-ZNRJEM Bearing & Race Assembly 1 Required
Federal Mogul (National) 470898 Oil Seal 3 Required
Federal Mogul (National) 6835S Oil Seal 2 Required
AXLE HUB ASSEMBLY Timken LM 501349 Outer Bearing 2 Required
Timken LM 501310 Outer Bearing Race 2 Required
Timken LM 603049 Inner Bearing 2 Required
Timken LM 60301 Inner Bearing Race 2 Required
CR (Chicago Rawhide) Inner Oil Seal 2 Required
STEERING KNUCKLE(S) Timken 21212 Bearing Cup 4 Required
Timken 21075 Roller Assembly 2 Required
Bronze Bearing Assm Upper Ball End Trunnion 2 Required
(No Part # on Assm.)
Don,
Thanks for sharing the detailed info and part numbers. What a wealth of knowledge to help out fellow 'Bolters with transfer cases in need of repair or refurbishment. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Donsz, thanks for the parts#. Is there a rebuild shop manual for this transfer case and do you know if the Dana 24 gears and shafts are inter changeable with the 23.
1. Got my Dana 24 rebuild kit from: https://cobratransmission.com/dana-24-bearing-kit-55050001-1 (at the time i was $67) My part number on the invoice is CT-BK24. The one on the url, is BK24-001, but looks the same. Note you need the seals as well as the bearings, the kit has them (I think the kit is cheaper than if you buy everything separate.
note: I see I have an invoice for one MRC 207M-00009 Bearing I purchase separately: I'm not sure why I bought it anymore, so check to see that it is in the Dana kit
2. You could also go to: https://www.danaaftermarket.com/spi...017110?catalog=PIMS_NA&partType=PART
and see if you can get the correct kit.
3. I don't know about the shafts (I bought two extra transfer cases for spares, just in case)
4. Attached is a PDF of the manual I used for rebuild (looks complicated, but was fairly straightforward). I have a number of NAPCO manuals I got from the old NAPCO site (now on Facebook) and I think they come up on eBay periodically. I hope you can read what I have attached (use magnify if needed).
don
Thanks don for the sharing the napco manual.
