8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#1472570 10/26/2022 1:30 PM
Looking for info on how close in inches to put the exhaust pipe and muffler from my wooden truck bed without using a heat shield. I will use a shield if I need to. I have a '54 with a red oak bed running a 305 Chevy engine using 2 1/4 inch OD exhaust.
Thanks in advance.
Use a heat shield. It is not worth burning your bed down.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
X2 - Cheap insurance
The radiant heat from the exhaust pipe can still "see" the wood and will heat it up. Safe distance? Maybe 3 feet? wink
The critical thing with a heat shield, is it needs to stand away from the wood to be effective. If you slap a piece of sheet metal right on the wood, it will still get too hot.
