| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 11 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 11 | Looking for info on how close in inches to put the exhaust pipe and muffler from my wooden truck bed without using a heat shield. I will use a shield if I need to. I have a '54 with a red oak bed running a 305 Chevy engine using 2 1/4 inch OD exhaust.
Thanks in advance. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Use a heat shield. It is not worth burning your bed down. | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | Use a heat shield. It is not worth burning your bed down. X2 - Cheap insurance The radiant heat from the exhaust pipe can still "see" the wood and will heat it up. Safe distance? Maybe 3 feet?  The critical thing with a heat shield, is it needs to stand away from the wood to be effective. If you slap a piece of sheet metal right on the wood, it will still get too hot.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
