2 members (Otto Skorzeny, Nick in Manitou), 113 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#1472577 10/26/2022 1:49 PM
Can someone please tell me how to remove the oil and temp
Lines off the gauge need to do some gauge removal and don’t want to break them off or take them off wrong and damage them
This is no longer fun
Curmudgeon
Curmudgeon
The oil pressure gauge is a simple removable copper tube. Unscrew the nut.
The water temperature gauge is a gas filled tube that must be removed intact. Bulb, tube and gauge is not made to be separated. Care must be taken not to bend the tube too much or it will crimp. The picture is of a 54 gauge but the 52 gauge is similar.
