There's no seal on the input shaft, but there is a gasket on the retainer that the throwout bearing rides on. Also, there's no gasket where the countershaft goes thru the front of the tranny case, but some sealant around the depression in the bell housing for that shaft can take care of potential leakage there.The countershaft also is exposed at the rear of the case, and may seep there if it's not real tight, but again, a little sealant can deal with that.
There's an exploded view in the service manual.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
There is a bearing nut/oil slinger that is threaded on the front of the clutch gear and staked in place. There is also a corresponding tapered portion of the bearing retainer that is very close to the bearing nut but is not a contact surface. The idea is for whatever oil that passes through the bearing is directed into a passage in the bearing retainer and returned to the transmission case. I have found many of the bearing retainers and the bearing nuts excessively worn which allows for the oil to just run out the front. It is difficult to remove the nut without a special wrench so many use channel locks which dents the outside and causes metal transfer to the bearing retainer, thus the beginning of a problem. The bearing nut/slinger is left hand thread. Fred
Kevin, thanks. I should have looked there first. This looks like a project I can take on. I went down to one of our local transmission shops and they quoted me $700. For that I'll give it a try.
Darren Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
I fabricated one from two pieces of flatstock I welded together then cut out the jaws to match the nut.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
