| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2022 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 29 | I have been looking for used 8 lug 15 inch wheels. My 65 C20 has lock rim 15 inch wheels. I am trying to replace. Did chevy trucks come with plain 15 inch 8 lug wheels back then? Just not a lot of 15 inch wheels around. A lot of 16 inch, and 16.5. Thanks, Stan | | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | Did you try the dealership with that recall letter you posted about in the 'spoon?  Other than that, I can't help.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Good luck trying to find a drop center 15" wheel for tubeless tires that will fit over the massive brake drums on that C20. You'll probably have to special order some that move the tread center way outboard. That does pretty radical things to steering geometry. There's just barely enough clearance for the drums with the straight-barrel 15" tube type wheels. Jerry
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Hey stans6400, there are 4 , 15" 8 lug wheels on Craigslist, Lansing , Michigan
