0 members (), 142 guests, and 2 robots.
Topics128,132
Posts1,056,730
Members48,454
A few months back I bought a 59 stepside Apache it has a stock 235 in it.
Parts I have for it in the house are a 268duration cam from Clifford cam, Fenton dual headers and a fancy triple ace intake from a '54 vet
So, looking for lifters. Do the years matter? The 261 from '55 will fit or nah?
I'm under the impression that I need to cram 261 parts inside this 250 because of that intake
What about valves? Is there an "up size" that we can put in the head so it breathes bigger breaths? (I got vortec valves in my amc 258 can we do something like that with the 848 head?)
Any advice otherwise,
aside from talking me out of doing this build cause it's fruitless. ima do it out of spite snd have an evil truck
59 3E 3600
The Vette intake is for a 235 with a very small cam, 24.5 degrees of overlap, and tweaking the carbs will be needed with that cam.
All 1937-early 1954 216, 235 and 261 camshafts are steel, and must only use compatible chilled iron (“milk bottle”) tappets. Biggest journal is 2.028".
Visual camshaft ID: http://tinyurl.com/3c3obzk
Late 1954-55 engines use large journal steel camshafts. Biggest journal is 2.154".
1956-1963 235 & 261 camshafts are cast-iron, and must only use compatible (common) cast-iron tappets. These are hard all over (but softer than the chilled iron’s contact surface).
What years show on the cam card?
The Powerglide engine used a 1/16" larger intake valve, will it help? IDK.
Brb about year thing = i had to email Larry to ask
Powerglide intake valves = thanks
The 261 exhaust valve is larger than the 235 or same?
59 3E 3600
I would contact Clifford to see what they recommend for the lifters to go with that cam.
If you have the actual Corvette intake that uses the Carter side draft carbs, contact carbking on this forum to discuss rebuild kits. Do you already have the Vette carbs? If you don't, you're probably better off with a traditional triple that uses downdraft carbs instead of the Corvette triple. With more options, you'll have more success piecing together a matched set of downdraft carbs. With a good progressive linkage setup, you can set it up for reliable normal driving and have the other carbs kick in when you jump on it.
I don't think the 261 differs from the 235 as much as you're expecting it to, so trying to use all the 261 parts you can in your 235 won't do much for performance compared to the 235 parts you already have.
H Online: Content
If you've got a real Corvette intake and matching carbs- - - - -sell it to a collector/restorer and you'll make enough money to build a couple of high performance engines. The power gain over a proper sized single carb is minuscule, and the Corvette setup is priced like it's pure gold- - - -not plated! Take anything Clifford tells you with a big grain of salt- - - - -they're long on unsubstantiated claims, and short on facts and figures to back up their "fertilizer". A 268 duration cam needs more compression than an 848 head can make without going to very expensive custom pistons, and the RPM range where the power would be made is at the very top of what the cylinder head is able to flow.
If you want lots of power and RPM, trash the six and install a small block V8. You'll get twice the horsepower gain at less than half the price.
No 261 part is an improvement... except the block, which is 11% larger, more effect than almost any single piece of speed equipment.
"Take anything Clifford tells you with a big grain of salt"
X2!
At one time, there was a disclaimer (or "qualifier") from Clifford that said "... when used with other recommended upgrades".
Like more CR, CFM, and header...
W/r/t compression: I agree, the cam will drop CCP and low speed torque (and any cam with its intake valve closing point significantly later than the stock cam), some of which will come back with a substantial increase in CR, but this probably mean $$$ pistons.
If you're going to use it with stock CR, advancing the cam position (all valves open and close earlier) will help slightly, but the piston may strike the intake valve (the exhaust is safe).
I just spent 10 minutes cleaning up this thread. If y’all can’t keep it civil this thread will go away.
So anyway
The cam from Clifford came… it’s a 1957 - 1963 CHEVY 216, 235, 261 HOWARDS CAMS 179992= lol.
Last edited by Justhorsenround; 10/29/2022 12:29 PM. Reason: Removed derogatory comments
59 3E 3600
Curmudgeon
Curmudgeon
On their website it says:
https://www.howardscams.com/mechani...1957-1963-chevy-216-235-261-howards-cams
HOWARDS CAMS 179992
SKU: 179992
UPC: 840793108121
Lift: / , Duration @ .050: / , Centerline: , Custom Grind / Custom Order,
Notes: Stock (O.E.) valve springs cannot be used.
So Clifford filled out the Howards spec sheet and placed the order. The cam is drop shipped to purchaser.
Clifford made a few dollars for middleman (dealer) fees.
What's the deal with the valve springs? Stock is not strong enough?
Clifford and JEGs etc. say nothing about that cam. Depending on intake/exhaust bias, duration @ .050, and LSA it may do almost nothing (too mild), or quite bit.
Do you have the cam card?
Just a guess: 268 is the nominal or lashed duration. Subtract at least 50 degrees for the .050" = 218.
Warm LSA 108: IO 26 BTDC, IC 62 ABDC, EO 62 BBDC, EC 26 ATDC, OL 52, OL triangle area 27 "units"
Mild LSA 110: IO 24 BTDC, IC 64 ABDC, EO 64 BBDC, EC 24 ATDC, OL 48, OL triangle area 23 "units"
Milder LSA 112: IO 22 BTDC, IC 66 ABDC, EO 66 BBDC, EC 22 ATDC, OL 44, OL triangle area 19 "units"
Note that the overlap triangle area (when both intake and exhaust valves are partially open) @ 108 is about 50% greater than @ 112.
Specs, please.
Gelalfett,
Your reply post makes no sense.
“BRB” from what?
You haven’t responded to the question posed by member “panic”.
If you want help, actively participate in the conversation please.
Thanks!
~ Dan
1951 Chevy 3 window 3100
Adverised = 13.5 intake opens, tdc overlap 29 degrees, 14.5 exhaust close…. 54.5 exhaust opens, 54.5 intake closes
Running clearance hot 0.022, valve lift 0.450, duration 249
Gross lift at cam 0.300, degree of duration @ .050 is 213.8
Serial number 57613 (lol)
I don’t know what any of that means other than ots gonna sound scary with no load … probably scarier in gear 🤷🏻‍♀️
59 3E 3600
Know what it means.
My point was, why post something like that 5 days after some one replied to your post with a question to try and help you out.
I’m out of this conversation. wave
~ Dan
H Online: Content
Originally Posted by Gelalfett
I don’t know what any of that means 🤷🏻‍♀️
Yep!
#1539461 03/08/2024 5:57 PM
One day I’ll finish this build, hoping in October … but we’ll see
Brakes,rear axle and tires are the only things actually finished at the moment blahblahblah
59 3E 3600
